Re: 1680 Combine
Posted by Brownie450 on December 11, 2007 at 03:09:16 from (207.177.82.175):
In Reply to: 1680 Combine posted by Tom Bateson on December 10, 2007 at 21:20:32:
Don't know about a 1680, but we've done the seals on our 1440 & 1460 without too much trouble. We took off the hydro pump & lines & then the slanted right-angle gear drive. We just used the skidloader to pull individual units & replace them. Get a tool from IH to re-install the seal. Be careful when getting the old speedi-sleeve off the crank. We used a 1/4 inch cold chisel to cut through it. If you had a heavy boom to lift the engine, that might not be a bad way, but you'd have to support the angle gearcase & hydro pump. Maybe a 1680 is set up differently--don't know. Good luck with it.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
