Re: 1206 Questions/help...Thanks
Posted by Owen Aaland on December 11, 2007 at 13:55:27 from (65.165.246.41):
In Reply to: 1206 Questions/help...Thanks posted by perrycountyfarmalls on December 10, 2007 at 15:13:14:
Take the inspection cover off the bottom of the clutch housing. You will be able to see the release bearing and levers. They are probably ground off. If they are OK then the clutch disk has likely broken up with broken pieces wedging between the pressure plate and flywheel.
If the free travel is OK and the clutch will not release, the tractor will need to be split to service the clutch.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
