If the fuel comes out of the carb after a bit of cranking, but does not continue to drip with the fuel valve on the tank open, The issue may be one of three items. 1} the timing is not right (plug wires on the wrong distributor terminals. (180 out) 2) intake manifold /carb air leak allowing massive air to get in ahead of the carb. 3) no vacuum pulling fuel into the cylinders.
TO fix #1 Be sure both valves are closed and it is on the timing mark, before setting the plug wire location.
To fix #2 Spray some propane from an unlit torch at all the surfaces of the manifold/carb head at manifold area while cranking to see if it takes off.
To fix #3 put your hand over the intake as El Toro indicates to see if there is a vacuum. Also pulls in fuel. If none, there may be a valve timing issue, or stuck valves. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
