Re: Questions and Opinions on D264 OH
Posted by K.B.-826 on December 11, 2007 at 19:32:19 from (66.188.192.10):
In Reply to: Questions and Opinions on D264 OH posted by BOBM25 on December 11, 2007 at 18:00:52:
I think you'll regret pouring a whole pile of money into something that doesn't get used everyday. I know I have. Here's what I would do on that engine- pull head, send to machine shop and have valve guides checked and valves/seats ground. Don't bother checking it for cracks, as all of those gas start diesels have cracks in the head, if you're not having any coolant leakage/compression in radiator, don't worry about them. I would then pull the pistons and sleeves. Get a good micrometer and measure the rod journals. If not in spec, then you gotta start thinking out-of-frame overhaul. If they're good, I would put in new sleeves, pistons, rings, rod pins and bushings, and rod bearings. I don't think I'd even bother looking at the mains, because you say you've got good oil pressure and I've heard mains for that engine are almost impossible to find and priced out of this world. Not sure what injector/injector pump work costs for those old gas-starts, but thats about the only other thing I'd look into.
