Being a straight bevel gear makes setting up this fit much easier. The service manual for the H emphasizes two things: backlash and alignment at the back (wide) edges of the tooth contact area. There are paragraphs about "heel" and "toe" but not being hypoid, you can't really do a lot about it. When putting my '51 H back together, a shim was taken from under the right side and put under the left side cage to bring down the backlash. Since the ring gear was moved perpendicular to the pinion gear, contact points weren't affected at either edge of the teeth. If you decide to measure the backlash, be sure to take all of the slack out of the differential carrier assembly to the right because load forces will always press in that direction.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
