Put it in neutral then drive the pin out. This is the one at the base of the shift lever just below the spring. When you get the pin out lift the shift lever up and with a lite look down to see if the three rails are lined up you can move them with a screwdriver mite need to fasten the clutch pedal down to relieve any pressure on the shift forks. They should be lined up or the tractor wouldnt move. What gear did you have when you moved the tractor. Does the tractor move when in second gear. Does it move in third and fourth and also reverse. If it moves in ALL the other gears you have a big problem.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
