Re: first try shimming H differential
Posted by Big Hunter on December 12, 2007 at 15:28:39 from (208.242.126.245):
In Reply to: Re: first try shimming H differential posted by riverbend on December 12, 2007 at 14:35:31:
I think it's called a dial caliper. has a magnetic base you set onto something stationary and has a meter with a pin sticking out of it, you place the pin touching the tooth ot the ring gear push a button to zero out the meter then turn the ring gear, it will tell you how much play you have between the ring gear and the pinion shaft gear
