Posted by georgeky on December 12, 2007 at 17:03:51 from (64.12.116.73):
In Reply to: TA in 350 Farmall posted by Salty on December 12, 2007 at 16:41:14:
Are no weak parts if operated properly. Most the time the rollers and ramp in the unit itself is shot. No way to know until you tear it down. If it makes a whining sound and acts like it want's to pull or does pull in lower gears but not high ones, it is likely the roller and ramp. The TA does have to be adjusted exactly according to the book. You may try that first. If you remove it from tractor a complete rebuild will likely be the way to go, as it is a big job to split the tractor in 2 places. The ramp and rollers can be done by only splitting at the rear end, but it requires some barnyard ingenuity to put it back together. I am sure more detailed and better info will come in a bit.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
