Re: '52 Super C Dimmer Resistor
Posted by Janicholson on December 13, 2007 at 08:51:23 from (199.17.6.122):
In Reply to: '52 Super C Dimmer Resistor posted by Mike Lumley on December 13, 2007 at 08:07:44:
A 3 ohm resistor that can handle 80 watts (power resistor should work fine. The wire resistors found in heater blower motor controls will also work. They need to be crimped into the circuit (both get hot when in use. They can be found at electronics stores, or the internet. The headlights use about 35 watts each, and will overheat and burn Too small of a power resistor. Some power resistors can be purchased with an adjustable band contact allowing the resistance to be adjusted from zero to 5 ohms. That would allow you to set the dimness of the lights. Be careful to insulate the resistor from case contact to prevent shorts. The insulation should be heat resistant. 100 watt resistors are pretty big. I hope this helps, JimN
