Posted by Janicholson on December 13, 2007 at 08:59:13 from (199.17.6.122):
In Reply to: cylinder sleeves posted by mark3006 on December 13, 2007 at 08:45:49:
The making of the tool is really the only good answer. The puck should be bore size then step to bore size plus .090" Then a 3/4" hole for ready rod in the middle. On the top, a bridge made from 2X4" rectangular tubing and blocking or a pipe bigger than the sleeve flange to pull up against provides the pull. use heavy class nuts on the ready rod.
Some use a welder to make four passes up the walls of the sleeve from bottom to top these shrink the sleeve when cool, allowing easy removal. Protecting the journals is important, and not welding too deep causing bore dammage to the casting is also important. I would make (or have made) the puller. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
