Re: cylinder sleeves
Posted by El Toro on December 13, 2007 at 13:49:05 from (71.179.119.160):
In Reply to: cylinder sleeves posted by mark3006 on December 13, 2007 at 08:45:49:
third party image
Here's a sketch of Keith's sleeve puller. You need to have have the puck undercut enough to fit the sleeve bore and the outside diameter machined enough to clear the block bore. With a hole drilled in the center to clear the 3/4 allthread rod. Hal
