Re: C/O on M gen.
Posted by Bob M on December 13, 2007 at 14:54:06 from (69.205.120.58):
In Reply to: C/O on M gen. posted by henryv1111 on December 13, 2007 at 12:51:09:
Another problem with the manual toggle switch: When the tractor is at idle it'll DRAIN 10 - 15 amps thru the generator unless you open the switch.
If it were mine I'd dump the C/O and install a voltage regulator since a regulator does a much better job of keeping the battery charged. (Use a regulator for a Super H, Super M, etc).
Or use the diode trick mentioned below...
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
