Re: battery box
Posted by Andy Motteberg on December 13, 2007 at 20:31:31 from (4.143.216.80):
In Reply to: battery box posted by Dillweed on December 13, 2007 at 11:52:27:
If you have the box that slides under the tank next to the clutch linkage, You can loosen the nuts on the bottom of the box bracket and slide the box out in install/uninstall the battery, or you can also remove the box to install it.
