Re: Farmall C valves
Posted by gene bender on December 14, 2007 at 06:15:55 from (67.55.226.214):
In Reply to: Re: Farmall C valves posted by Bob on December 14, 2007 at 03:07:26:
You should take a compression check first. What will be the use of the tractor? A little smoke realy aint serious unless we are goint to farm 60A. If you want to do a complete job sleeves and pistons will run 280 grind crank and bearings 225 head can run 300 gaskets 55 all things to consider. Then you will need a new battery and possible starter work.
