Posted by karl f on December 14, 2007 at 11:47:03 from (64.83.221.111):
In Reply to: Re: 656 gas carburetor posted by clint315 on December 14, 2007 at 10:41:14:
ours has an IH carb on it, and it was one of the last ones built. we're original owners. only problems have been dirt in various places and the solenoid, about every 2-5 years ;). and the manifold heater spring was wired since the anchor pin rusted away. maybe the carb on yours is off a much smaller displacement engine since the number doesn't match in the parts book. the jet would be too small, causing the need for choke. are you needing to choke no matter what or only at idle? the idle is completely adjustable, and neeeds to be set right for it to run below full throttle.
you should be able to get the right jet by ordering the one for your tractor, since the carb body is about the same between that design. otherwise if it's a cluster, just get a new carb that is designed for the engine. anything with a warranty is better than completely wrong stuff you have now. if you want to tinker a little more, find out what size the jet needs to be and drill it out.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
