340 utility is split
Posted by jimmY Minnesota on December 14, 2007 at 15:48:15 from (66.103.165.20):
how do i remove throwout bearing inside clutch housing., the clutch rod wich goes throug clutch housing on both sides is supposed to be pushed through from right side to leftside in order to drop out bearing from inside housing, i cannot get clutch rod to move through block, i have checked every where for split ring retainers or a pin that may need removal, but see nothing on either side of cluth rod or housing... thanks for help anyone
