Re: My 300 and its idiosyncrasies
Posted by Andy Martin on December 15, 2007 at 04:59:49 from (63.99.111.169):
In Reply to: My 300 and its idiosyncrasies posted by chuck craig in SUNNY SOCA on December 14, 2007 at 21:20:54:
The big belt also runs on a split sheave on the water pump. It should have a square head lock screw on the front half, which is adjustable. It may not have been adjusted recently so you may have to loosen things up with penetrant.
There are square lugs on the front half to aid in adjusting with a punch however it is cast iron so don't overdo it. A brass punch will help you to not hit it too hard.
You may not need to adjust it if you still have the adjustable sheave on the generator.
Neither belt has to be tight, just tight enough to spin the appropriate parts. Overtightening will wear out the bearings quicker.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
