Re: ??'s 240 fast hitch hydraulics
Posted by Janicholson on December 15, 2007 at 07:30:10 from (66.173.50.28):
In Reply to: ??'s 240 fast hitch hydraulics posted by glennster on December 15, 2007 at 05:46:26:
The problem may be the hose connection. There is a limiting valve in the system that prevents radical dropping. I know it is on 350s, not sure where it is designed into yours. If it is backwards, it would act like that. Normal valve action is backward and down for down, and forward and up for lift. Even if this is correct, the valve may be at the cylinder and be backwards. Also make sure there is no dirt in the lever slot that might limit the lever travel, it must go all the way to the lift position. Good luck, I hope this helps. JimN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
