Re: Starter
Posted by JT on December 15, 2007 at 14:47:37 from (99.203.250.50):
In Reply to: Re: Starter posted by old on December 15, 2007 at 13:11:51:
Rich,
don't waste your cash on a starter rebuild shop. Take it off, take a fine emory cloth, put in a vise,clean the brass commutator like you would a shaft with the emory cloth, then take a broken hack saw blade and clean the grooves on the commutator, when you get it apart, you ill see what I mean. They are very, very simple to work on. Also check the springs on the brushes to make sure they are not weak. If you are not 100% sure on brushes and springs, go to starter shop, get a bunch of Delco Remy starter brushes and springs and keep 'em around, then put back together and put a little grease in the bushings at each end of the shaft. I know you have the ability to do this simple job. If you were not 5 hours away, I would show you how to do it.
Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
