Re: ??'s 240 fast hitch hydraulics
Posted by glennster on December 15, 2007 at 15:20:52 from (68.60.242.156):
In Reply to: Re: ??'s 240 fast hitch hydraulics posted by georgeky on December 15, 2007 at 14:27:50:
from what i read in the owners manual, the hydraulics can be adjusted for one way or two way. also under the seat, there is a cast iron ?? box about 1/2 the size of a cigar box and half as thick. the lines come from the valve under the steering column in steel lines and then connect to this box. coming out from under the seat heading back to the cylinder they are rubber coated hydraulic lines. maybe flip the two lines at this block? there are no linkages at this block, nor is there any other knobs, levers, or adjustment screws that i can see, just looks line 2 lines in, two lines out.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
