Re: Farmall C will not start
Posted by riverbend on December 15, 2007 at 16:13:35 from (208.160.33.240):
In Reply to: Farmall C will not start posted by percy on December 15, 2007 at 14:03:40:
If fuel is dripping out of the carb, it is flooded. At -10F it will have to be a little flooded to get enough gas to evaporate and make the motor run.
With my H, three cranks with the choke closed (and the clutch pedal held down), open the choke, 7 clicks on the throttle, ignition on, and crank it again. When it fires, it needs about half an inch of choke to keep it running.
When that doesn't work, I have a magnetic heater that I stick on the manifold above the carb for a couple hours and then try again. As a last resort I jump the starter with a 12V booster pack.
It is looking like this could be a cold winter, so if you need this tractor to run, you will have to figure out the starting drill and stick to it. Sorry.
Greg
