Re: Zentih Carburetor on BN
Posted by kaptkimbo1 on December 16, 2007 at 16:18:43 from (75.41.13.164):
In Reply to: Zentih Carburetor on BN posted by kaptkimbo1 on December 16, 2007 at 09:44:51:
I pulled a plug...dry..no gas. I repalced the electrical system last winter new plugs, coil, distributro cap etc.... I was going to try to make sure I had spark...and double check timing... my battery was geting low so I'm leaving charger on it
