6-12 volt H
Posted by lee m cramsey on December 16, 2007 at 17:04:12 from (65.73.245.123):
I was told to install 1156 12 volt bulbs in place of the original 6 volt bulbs. My question is, are the 1156 bulbs polarity sensitive? I have 12 volts in the socket and it will not light the bulb. I am using a postive ground system. I also started this tractor with 12 volt and the generator charges the battery. The gauge show good charge. I have not converted this to 12 volt. Do I need to convert? Will it destroy the generator? Thanks for your input. Lee
