Posted by Fromjb2 on December 16, 2007 at 19:08:03 from (99.241.179.24):
In Reply to: Re: 674 IH TRACTOR posted by Robert Hasserd on December 16, 2007 at 13:32:04:
Robert, according to I&T Shop Service Manual. 1)Remove pressure line going to PTO clutch at tee and connect pressure gauge. 2)With warm hydraulic oil and PTO engaged, run tractor at 2200 RPM and check for pressure of 220 psi. If pressure is low remove the plug on top of MCV valve to the right of the PTO spool valve and add shims till pressure is minimum 220 psi. 3)Reconnect pressure line and remove cap from tee and connect pressure gauge. Run tractor at 2200 RPM with PTO engaged and if sealing rings and PTO clutch are good, pressure should be 220 to 250 psi.
Since you had one stuck pressure regulator in MCV maybe PTO pressure regulator is stuck as well.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
