Re: '53 Super H Electrical
Posted by John T on December 16, 2007 at 19:28:44 from (66.244.83.147):
In Reply to: '53 Super H Electrical posted by Matt Weltz on December 16, 2007 at 17:49:17:
Matt, if the starter is mechanically stuck/jammed so it cant turn, when you do try n start it the lights would dim down badly (if the switch/solenpoid n cables n connectiosn are alllllllll good) and/or the battery voltage drop way down plus there ought be some cable heating and/or maybe some crackling somewhere?? A stuck starter ought to cause a high amp draw from the battery and that n heat can cause a connection to go bad somewhere from arcing n carbon SO CHECK THE CABLES N CONNECTIONS CUZ IT MAY HAVE STUCK AND THAT CAUSED A POOR CABLE OR CONNECTION!!!!!
As posted below loosening the starter and/or rocking the engine can free it up
IF ITS NOT STUCK SEE BELOW
Is the battery still charged up???????? If in doubt give her a good charge n try again, that may be the problem
First thing I suspect (if its not the above) is a poor battery or starter or switch/solenoid connection somewhere. Id remove n clean n wire brush each n every battery n starter n switch/solenoid n starter post n ground conenction TRY THAT NEXT
Okay iffffff the battery is charged and iffffffffff allllll cables n grounds n connections are all okay and she still dont crank and shes NOT stuck/jammed when you try n crank her,,,, if the lights dim badly or battery voltage drops badly I SUSPECT A BAD STARTER (bushings or armature etc) but if they dont dim a bit n voltage stays about the same, its EITHER a bad switch/solenoid or the starter may still be bad like the brushes.
You can see if its a switch/solenoid problem by jumping around it if you use big heavy jumpers n momentarily attach the BAT input side over to the starter output side or jump from the bat input side (or the ungrounded battery post) direct to the starter post PROVIDED ITS A SWTICH OR A SOLENOID WHERE THATS POSSILBE, cuz if its a mechanical saddle type push switch you cant do that.
let us know what happens
John T
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
