Re: Will a 54A blade fit a 140??
Posted by TheDurk on December 16, 2007 at 21:52:22 from (71.125.68.239):
In Reply to: Will a 54A blade fit a 140?? posted by Mike Farmer on December 09, 2007 at 20:17:08:
1fortyfanatic said: (quoted from post at 21:02:13 12/10/07)
third party image
Dave, your machine is very similar to my 1966 International 140. Except for the throne and the battery moved under the seat from the hole between the control panel and the hydraulics. Was this done in order to use a larger battery? How big is it? The only modern battery I have found that fits mine is a Group 26 and I find it a little anemic in cold weather. Mine came from the dealer with a Meyer ST-72 and a frame that bolted to the final drives and the tabs on the mower mount behind the steering gear. 5/8" wire cable goes from the rockshaft over two pulleys to the A-frame. Going strong for 39 years, and Meyer has parts if I ever need them.
