Posted by Hugh MacKay on December 17, 2007 at 02:24:52 from (216.208.58.109):
In Reply to: Cubs as snow machines posted by Pat-CT on December 16, 2007 at 14:56:17:
Pat: I've never plowed snow with a Cub, however I can tell you a Super A, 100, 130 or 140 are about 5 times the tractor a Cub is on most work. We had a Cub for 8 years when new, and traded it for a 130. Cub will come in slightly over 1,500# and the others around 2,400# shipping weight. The SA, 100, 130 or 140 are very little longer or wider, thus are just as manuverable in close working quarters.
While the Cub is a nice little tractor, it's built quite different from all the larger Farmalls. Bear in mind ours was bought new, yet was always a pain in the butt on carburation and ignition. The little 60 cubic inch engine turns well over 2,000 rpm to come up with 10-12 hp, that in itself almost doubles engine wear over the others. 1st and 2nd gear are too slow for most work, yet it has little more than enough power in 3rd to move itself.
Our driveway at home was quite a steep pitch, and one had to do everything just right to make that grade in high gear with the Cub. 130 would climb that hill very little off idle in high gear. Last but not least those Cub engines don't have sleeves, by now they have to be near the end of their rebuild life. My recomendation, I you want a show tractor for little use, buy the Cub. The others are useful, and every bit as sharp at shows.
I realize this may insult some Cub owners, however I speak from experience.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
