Re: I've just about had it with leaks
Posted by glennster on December 17, 2007 at 10:43:19 from (76.224.4.16):
In Reply to: Re: I've just about had it with leaks posted by Carden on December 17, 2007 at 10:26:47:
top one is a leaky seal on the brake drum. you need to pull the cover and the drum and then pop the seal out. the lower one looks like the inspection cover under the clutch. could be the belly pump seals are leaking, or the trans input shaft or the belly pump drive shaft. none are hard to change, takes a little time, and a handful of grease.
