1st pic is the set screw used to take up initial slack when adjusting brakes on the bottom of the brake drum and what you are showing is the bottom of the drum. If you have an oil leak there then you probably have an oil seal leaking on the outer end of the diferential shaft behind the brake drum. I cant really see the angle on the second one but I'm sure someone else will advise on that MTF
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
