Re: I've just about had it with leaks
Posted by glennster on December 17, 2007 at 12:38:51 from (76.224.4.16):
In Reply to: Re: I've just about had it with leaks posted by Carden on December 17, 2007 at 10:55:47:
at this point, i would wait till spring to change the seals. it wont hurt anything right now, just annoying. to do the brake seals, you need to remove the pedals to get the covers off. then pull the drums, pop the seals and reassemble. trans seals or belly pump seals arent that bad to do either.
