Posted by big fred on December 17, 2007 at 14:50:14 from (130.76.32.16):
In Reply to: Re: ih 300 steering posted by clifford casavant on December 17, 2007 at 14:38:59:
I don't know how the worm gear is attached to the shaft. The reason I had to take mine apart was that the output shaft bushings were badly worn, the worm shaft was okay, so I didn't mess with it. If it's keyed to the shaft, it's probably a busted key and easy to fix. If the sector gear is busted, the busted tooth should still be in the gearbox, and can be welded and re-ground. The manual steering does take a good effort, so that might have been the extent of the problem. While it's apart, though, you can check it out and replace the bushings and bearings. I had to have bushings made, the shafts built up and reground, but yes, most anything can be fixed.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
