See if it will fire with starter fluid. If yes it is a carb. problem. Is the gas in the tank old? Did you clean the sediment bowl? If you remove the gas line from the carb can you get a steady stream of gasoline out the pipe? Those supply lines were bad to clog on the old farmalls especially when they would set up for a while.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
