F-20 clutch disk and pressure plate, what will fit
Posted by Scott Rukke on December 17, 2007 at 18:26:47 from (67.183.230.71):
Are there any other disks and pressure plates that will fit the F-20? Are the Regulars, F-12, F-14 or F-30 the same?
