Re: any body got a 560 handy??
Posted by ny bill on December 18, 2007 at 09:49:28 from (66.24.240.172):
In Reply to: any body got a 560 handy?? posted by glennster on December 18, 2007 at 06:57:34:
the panel on the 560 has a wider strip on the bottom, and the 560 narrow ribs are still wider than the narrow ribs on the 240. the pattern on my 340 appears to be the same as the 240, in case you run across panels from a 340. my 560, 340, and 240 all ended up in the same barn this winter, so the measuring was easy. hth.
