Posted by CENTAUR on December 18, 2007 at 18:16:06 from (71.154.211.188):
In Reply to: choke cable for a 560 posted by JK in WL on December 18, 2007 at 17:07:50:
VERY CAREFULLY. Just kidding.I think you have what is called a universal(BOWDEN CABLE)which are easy to work with.Put thru the mounting hole,then put on lock washer and nut&continue in a(SANITARY MANNER)till you get to the final bracket.Then use a short nose diaginal pliers and spilt the outer casing so you can cutthe outer casing ONLY.If you have not done this before,practice on the end as Ithink it is too long as is.The inner cable is soft and can be easy to form as nessasary. CENTAUR
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
