Re: what to check when buying a 1066
Posted by GeneMO on December 19, 2007 at 12:42:53 from (76.0.17.196):
In Reply to: what to check when buying a 1066 posted by eurofarmer on December 19, 2007 at 09:44:28:
Not TA related, but we had lots of trouble with the front end. The bushings in the power steering and tie rods, etc. This all got loose and sloppy way before it should have been worn.
Also the cab left a lot to be desired, at least on the earlier models. Doors rattled, poor fitting , etc.
Gene
Gene
