Re: what to check when buying a 1066
Posted by Hugh MacKay on December 19, 2007 at 15:53:29 from (64.228.11.58):
In Reply to: what to check when buying a 1066 posted by eurofarmer on December 19, 2007 at 09:44:28:
Thinking of buying a 30 year old, 100+ hp, 2 wheel drive tractor, first thing you should check is your head.
