Re: wheel/ axle noise on farmall a
Posted by gene bender on December 19, 2007 at 18:37:45 from (67.55.226.214):
In Reply to: wheel/ axle noise on farmall a posted by james croft on December 19, 2007 at 18:20:44:
Those bolts that hold the rim. There is four of them. You need to take off the nuts put some oil on the threads and reinstall they have to be real tight. Its better if you have an air impact tool to get them real right. Mite need to do the same on the center ones.
