Re: wheel/ axle noise on farmall a
Posted by Hugh MacKay on December 20, 2007 at 02:42:32 from (216.208.58.170):
In Reply to: wheel/ axle noise on farmall a posted by james croft on December 19, 2007 at 18:20:44:
James: Clicking noise is usually wheel loose between rim and hub. Looking is not a real test, you got to put a wrench on it. I don't altogether buy gene's air impact, unless you get into 1" drive or larger, most of us can overpower and impact with a good 3/4 drive socket and 4' handle.
Anytime wheels have been off a tractor, you have to re-tighten a few times after the tractor has been used awhile. Plowing snow will loosen them about as quick as any work. I had this with my 130 the other day, had a flat tire back in the summer and wheel was off at rim, tractor had done a bit disking since. We had a heavy snowfall here last weekend. 30 min. into my plowing I could hear the clicking, got out the big wrench and cured the problem.
