Posted by Steven f/AZ on December 20, 2007 at 06:39:22 from (216.67.213.217):
In Reply to: problems with my H posted by hank woll on December 20, 2007 at 05:57:36:
If the pipe going into the manifold is loose, water runs down the muffler and exhaust pipe directly into your engine - that could be part of the cause of hard starting.
There are two ways to go about fixing that - buy a new manifold for around $150 or so plus shipping. OR you can unscrew the pipe, get a 2" pipe thread tap and run down the manifold (vacuum out the shavings!) and a new 2" pipe to screw into it with some high-temp thread sealer. The second solution is cheaper if you have enough left of your threads to repair...
Losing the battery could be a short or bad regulator or switch... I'm not real bright on the electrical so someone else will need to jump in with suggestions...
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
