Re: problems with my H
Posted by Andrew Z on December 20, 2007 at 06:42:38 from (12.76.153.100):
In Reply to: problems with my H posted by hank woll on December 20, 2007 at 05:57:36:
how old is the the battery?, is it a mag, or distributor? could be a bad switch. Second if you have a loose exhaust pipe water will run in there like crazy, it hits the muffler and runs right down in there. I would cover that up before you get more in there. You can tap the manifold out and just buy a new niple to but in there, if the manifold is not completly shot.
Andrew
