Re: 454 shifting problem
Posted by Fromjb2 on December 20, 2007 at 13:16:39 from (99.241.179.24):
In Reply to: 454 shifting problem posted by Harold Kelley on December 20, 2007 at 07:17:42:
Hi Harold is the grinding into high range from a stop or while moving? There is no synchromesh between lo & high only 1 thru 4. As for jumping out of high range, I would check the adjustment on the range transmission control rod. Re sticking clutch unfortunately that is one of the problems with the new metallic pads on the clutch disk. Any moisture or high humidity and the pads will rust to the pressure plate and flywheel. Same happens on cars & trucks with disk brakes. Give me the old asbestos pads.
JimB
