Re: Farmall H starter problem.......Help needed
Posted by Tom43 on December 20, 2007 at 19:46:13 from (70.142.42.80):
In Reply to: Farmall H starter problem.......Help needed posted by Mark Wiggins on December 20, 2007 at 11:18:38:
If you have a 6 volt system it can't be a stuck Bendix or the high current draw would be dropping the voltage below 5 volts. Assuming you have the factory 6 volt system you have an open inside the starter, a bad connection between starter and bellhousing, or a bad connection on either or both ends of the ground cable.
