Posted by Marty K on December 21, 2007 at 07:08:28 from (128.251.109.118):
In Reply to: adjusting 450 clutch posted by Hoss357 on December 21, 2007 at 04:09:55:
It's been a while since I adjusted mine after getting a new disc for it, but I'll give you my two bits. I'm assuming your clutch and flywheel are together in the tractor. You have to back off the lock nut and turn the adjusting screw for each of the three fingers that press against the throw-out bearing until there is just clearance between the fingers and the bearing face. It's hard to work under the tractor in that small opening into the clutch housing so be patient. Try to get the spacing even between the fingers and the face of the bearing so the clutch disengages evenly. Adjust clutch pedal play with the turnbuckle on the clutch rod.
My original adjusting screws had hex heads on them, but the replacement had slots for a flat screwdriver which makes it near impossible to adjust on the tractor. I put the old hex head screws back on so I could adjust it with everything all put together. I've attached a poor picture of the flywheel with the clutch installed and you may be able to see the finger adjusting screws. I hope this helps a little.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
