Re: snowplow w/ a Super C.
Posted by Andrew Z on December 22, 2007 at 16:58:16 from (12.76.157.28):
In Reply to: snowplow w/ a Super C. posted by Josh in Maine on December 22, 2007 at 13:50:50:
I had a lite 6' blade on my Super C, works really good good size tractor to plow with, but i had mine on the fron of the loader. As others said the old fishers are really heavy, I have one on a H and it really makes it a bear to steer! Also 8' is really a pretty big plow if your plowing a rough area, or uneven terrain you may have problem with that setup. You will need at least 2 sets of weights and i had a weight box set up on my fast hitch too. I was able to plow with out chains though. Good luck and i would look for a smaller and lighter blade at a junk yard. Theres one around here thats has a number of them so i woiuld think in Maine you should have pretty good luck.
Andrew
