Re: fuel tank
Posted by Hugh MacKay on December 23, 2007 at 15:24:12 from (209.226.247.117):
In Reply to: fuel tank posted by jeeper on December 23, 2007 at 07:31:18:
jeeper: What precisely is wrong with your tank? Is it physical dings and dents or leaking around the mount that attaches it to the hydraulic unit.
My 130 started leaking around the mount about 13 years ago. I cleaned it up, used an epoxy and coated the whole bottom of the tank, close to 3/8" thick at the mount, tapering off at both ends. I sanded it up, painted the complete tank. That was to be a temporary fix until I found another tank. That was 1994, I use this tractor a lot, even give it some hard use plowing snow. I say hard use plowing snow as I believe the bumps and vibration of plowing snow to be very hard on the sheet metal in general. My temporary tank is still on there, it has never leaked since, this is my beater tractor that gets used for rough use, plus my many experiments with equipment fabrications.
