Posted by Owen Aaland on December 23, 2007 at 16:19:54 from (65.161.86.40):
In Reply to: 1086 shifting posted by GB on December 23, 2007 at 15:44:00:
How does it shift when the engine is not running? Repair any worn linkages to get it shift smoothly.
Make sure all the cab mounts are in good shape. Check to see that you have the clutch linkage pivot mounted to the cab and not the clutch housing. Yours may be new enough to have come that way from the factory. Make sure all the clutch adjustments are as they should be. Get in the habit of lifting the pedal a little bit off the floor when actually moving the shift levers. That releases the transmission brake to relieve any windup on the transmission gears.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
