Posted by GD720D on December 24, 2007 at 14:24:42 from (66.226.101.193):
In Reply to: oil seal posted by NCCUB on December 24, 2007 at 13:15:08:
Disconnect battery. Remove hood and gas tank. Take wiring harness loose from generator.Remove throttle linkage. Can't remember everything that has to come loose but if it is connected to the engine and the rear of the tractor it has to come loose.Support both ends of the tractor.Remove thbolts that hold the engine to the clutch housing. Roll engine forward. Remove clutch and flywheel. Rear seal retainer is bolted to back of block remove retainer. If seal is loose in retainer the retainer has to be replaced. Also check engine oil pump above and to the right of the retainer. Posssible that gasket can leak
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
