Power beyond plug
Posted by Hayfarmer on December 25, 2007 at 13:09:04 from (66.243.241.56):
I have a loader on an older JD tractor, 430U, Want to change valves so got a 2 spool valve, also got the power beyond plug for it. Open center. Current plumbing is pump to loader valve in, loader valve out to 3 point on tractor. There is a third hose from the bottom of the relief valve to the reservoir. On the new valve instructions it shows a line from the outlet with power beyond plug in it to next valve, in my case 3 point, and a second line to reservoir. I am not sure of the purpose of the line to reservoir. It Ts with second valve output. This is not a high pressure system, 1200 to 1500 max. If I use the line from Power beyond valve to 3point, which alrady bleeds to reservoir, do I need the second line? 3 point has worked fine as is without power beyond. Guess I am not understanding the whole thing. I thought as long as you had an open center system oil flowed through it until a valve was moved, then was directed to the load.
