How long has it been since it ran the last time? You definately are describing a fuel starvation issue, and if the tractor has been allowed to just sit for some time, most likely the needle valve in the carb has become stuck, or the float hinge pin has become corroded and will not allow the float to drop down and allow more fuel to come in. You will probably need to remove the carb and open it up to cure it.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
